bigmark1972
Industrial
- Jun 11, 2003
- 56
Pictured below is a PCB from a tool changer in one of our older cnc machines. One of the LED's has been damaged and I would like to replace it. Parts are hard to find for this older unit and if I can ID this LED it should be an easy fix.
It's a 3mm dia LED, the circuit board has IH T-D94V-0 Printed next to the other LED's. I am not sure if this is even relating to the type but it could help? I know the board itself is 24VDC, the LED's have a dome top and are clear. Any ideas on what I could use to fix this board would be appreciated.
