Need physical properties of Shell Heat Transfer Oil S2
BCA2004
Chemical
Oct 11, 2011
3
Has anybody defined Shell Heat Transfer Oil S2 as a component for simulation?
Googling for "Shell Heat Transfer Oil S2" gives all the physical property data that I can think of needing as the first response.
Matt
I have got the technical data sheet for the oil,but it only has IBP of the fluid.
What are you trying to do? The maximum film temperature is listed at 340 deg C, versus an IBP of 355 deg C. You shouldn't need a boiling curve for design, I would have thought.
Matt
