I have an electric vehicle, built by a hobbiest, that I drive into town occasionally. His "engineering" leaves a little to be desired. I've already made some improvments, and this is the next one.
A gas engine car typically has a belt-driven power steering pump. This car has an electric pump from a Subaru. The pump is wired so that when the ignition is in the ON position, the pump gets 12v and flows at full power.
What I would like to do is use the vehicle speed sensor, or add another sensor (wheel hub, axle shaft, etc) and as vehicle speed increases, make the power steering pump motor decrease in speed. Finding motor controllers seems easy enough, as there are plenty of options from fields such as battle bots, but I'm having trouble finding anything that will do what I want to do- as frequency from a sensor increases (the OEM VSS provides a +5vdc square wave) make the motor slow down.
Any ideas?
Any ideas?
