NCEngineer
I know this forum is mostly for on-the-job engineering questions, but I am planning a 1.5 story, 2 car garage build in the next few weeks and I wanted to get some expert opinions before making any big decisions. I am trying to save costs by doing the drawings myself. I am also want to do the site-prep (dig, set forms, & ready the site for pouring concrete) myself with the help of my two able-bodied sons (17 & 21 yrs old) and my ex-contractor neighbor. We plan to have a contractor come
We have decided to go with a monolithic slab for the 26' x 36' (outside dims) garage to avoid multiple days of concrete pours. Also, the upper 1/2 story will be setup for my wife to use as a crafting room and I plan to use some of the main floor space for a workshop. However, I am a mechanical design engineer, not a structural or concrete engineer, so I feel a little outside my comfort level shall we say...
The ground at the site is "relatively" flat, but it seems to 'dip' in the middle of the 26' edge. The soil conditions are about 24-48" of sandy loam soil on top of very hard NC clay (this is based on other post hole digging and tree planting done in my yard, not on a specific soil analysis). Also, after a torrential rain (say 2"/hr) we will have standing water in some of the area we have marked out for this garage. Granted, this doesn't happen very often, but it does happen.
According to the local inspector that I talked to, rebar is not required, and the depth of the "footing" section of the monolithic will have to go 12" below grade, with a 6" minimum above grade.
Some questions:
1. Do I need a vapor barrier because of the rain issue? We would like to seal or coat the concrete floor in at least the workshop area.
2. What about wire mesh vs. rebar? I understand that cracking should be expected, but I want both to minimize costs as well as maximize the structural integrity of the building/slab.
3. What material should I use for a sub-base? Again, I want to maximize integrity and minimize cost.
4. What about finish? joints? other stuff I have no idea about?
Thanks for any and all help I receive. I apologize for the length, but I hope you understand my situation better.
Sean
Some questions:
Sean
