Hi folks, I have a little design job that involves using a vertical reciprocating motion (i.e. a finger repeatedly pushing a button) to move a lead screw forwards incrementally. Once the carriage that is mounted on the lead screw is at it limit it needs to be returned. The picture at the link below describes my currect concept for achieving this motion. (Apologies, I had no success inserting this image).
As you can see, the vertical "actuation force" moves the rack down and drives the pinion gear clockwise, thus moving the lead screw forward. Upon releasing the downward force the spring returns the rack. The pinion is mounted on a one way bearing so when the rack moves back up the pinion freewheels and hence motion of the lead screw is the unwanted direction is avoided.
This issue I have centres around how to return the carriage that sits on the lead screw once it is al the way along the lead screw. You'll notice that in image the rack is not in contact with the pinion gear. This enables the lead screw to be rotated anticlockwise without the assembly jamming. Obviously it is undesirable to have the rack and pinion out of mating and may cause a clash of gears when engaging the rack and pinion.
Does anyone have an alternative way of allowing counter clockwise motion of the shaft to return the carriage without having the rack and pinion come out of contact to allow this?
I hope I've explained myself clearly, please ask questions if there's something I need to clarify.
Thanks very much all.
