If this is the wrong forum for this question please correct me.
I need to conduct some drop tests on a device about 1ft. sq. and weighing about 5lbs. I'll be testing impact forces but I only need to go between about 10Gs and 200Gs. The equipment just needs to tell me what the G reading is at impact given drops from different heights. I can easily make the necessary jig with a ramp and roller guide bars.
My question is for a solution to find inexpensive (used is fine) equipment to do this. The least expensive I've found online is about $1200 (new) for an accelerometer connected to a PC with an associated program, which is about twice as much as I can afford right now. I've had no luck finding used alternatives.
Any suggestions are very appreciated. I'm willing to make one out of parts you may recommend as long as the results from the readings are reasonably accurate, consistent and the reading display, whether mechanical or electronic, "holds" the reading until it's re-set. Thank you.
Bret
Miami,FL USA
Bret
Miami,FL USA
