Hey everyone...
I am new to this forum and I am doing my first fluid piping/pumping project. My question is either very basic/simple, or very complex. I am not sure at this point??
I have 3 reservoirs which are identical in size and dimensions. They are each filled with the same solution. The quantity of solution in each reservoir is also kept the same. All 3 reservoirs are also at the same height off the ground.
I have one pump (500 gal/min, 70ft).
I need to setup a piping/pumping system which will draw the solution from each reservoir at the same flow rate of approximately 150 gal/min. The pipe coming off each valve, one at the bottom of each reservoir, will be 4" diameter.
Is there a manifold/header that enables the liquid to be suctioned (by the pump), at the same flow rate at each manifold/header entry point??
Is there a simple way of doing this??
I was going to have a pipe come down from each reservoir to a common header, which is capped at one end, with the pump on the other end. However, the flow rate from the reservoir closest to the pump will be the greatest, followed by the next closest etc...
I do not really want to put any flow regulators/restrictors on the suction side of the pump if possible...
Can anyone help me out with this???
Greatly appreciated...
Jack M
Jack M
