M
MBuchholtz
Guest
I recently used a technique that gives Pro/E the ability to export a drawing file as .PDF file.. The files are exported as the same name as the drawing file... The Drawing file name is for instance YTX2345-302.drw
The batch file then creates YTX2345-302.plt and then converts that into YTX2345-302.PDF
I don't suppose any of you might know a way to change the batch file so that it will delete the (-) out of the output file name???? So that the file exported would read YTX2345302.PDF
HEEEEEEELLLLPPPPP!!!!!
