Need help “Describing Structural Components to a Layman”. 1
Ron247
I have a case I am working on that I already see that I have to describe the possible structural components used to assemble a structure. The description has to be able to be understood by a typical layman (i.e. juror).
I have chosen to approach it as “ All structures consist of 3 possible components, Stick-like, Sheet-like and String-like. I intend to then outline the entire set of possible distortions (strains) you can do to these 3 possible components. The list I present may have items that are not needed or may have missing items. I need input on both. Being blind-sided in court because of poor preparation really sucks. If you would like to help, please see the attached document for the full scope.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1555132088/tips/Distortions_k4q9du.docx[/url]
Ron247 said:
The basic yard stick is still the best axial demonstration except I rarely see new yard sticks. Has that gone away with rotary dial phone?
If you're in the market for new wooden yardsticks, I saw them in the sewing department at Walmart recently.
