Need equipment: "stud adapter" with 5/8"-11 and 1/2"-13 ends 1
astor10
I've been searching for a bit now through industrial suppliers with no results. I need a threaded steel stud that can connect to two different thread sizes on its opposite end (5/8"-11 to 1/2"-13). I've found connectors and couplers but I would prefer a single piece of rigid metal. Perhaps this is something that needs to be custom machined but I may as well ask. Any leads are appreciated, thanks.
Do you need a male(double ended stud)or female connector?
What material?
How many?
If it is small number your best bet is a local machine shop.
Yes, i should have mentioned that, male-male double ended, any type of high strength steel will do although preferably stainless, and I will be needing just 4. Thanks.
Have them made at a local machine shop.
Nick
"Speed costs money boys, how fast do you want to go?"
I have to echo DDRSS10's post that your best bet is a local machine shop.
If they can't thread a double ended stud you can get a 5/8-11 Class II 304/316 SS stud of the required length and turn one end down to 1/2-13.
I know this sounds too obvious but if your connecting these two female ends with male studs then I would think one end might be left hand thread and the other right hand, something to check before you get to the machine shop.
I'm not a real engineer, but I play one on T.V.
A.J. Gest, York Int./JCI
