Need company to help design/prototype u-neek gate valve
ThreeB
3
Working on a very u-neek 7/8" gate valve and need a company to help finalize design and prototype, and possibly mass produce.
Thanks for your time and any help brothers.
Valve: - very low psi
-light weight aluminum
-single hand held and operated
-on/off switch not lever
How many thousands can you sell, per day?
Mike Halloran
Pembroke Pines, FL, USA
It would be more towards the one thousand a month mark. Most likely
When you say you're "working on" this valve, do you mean just scheming up the idea ("skeeming" to you probably), or do you mean you have actually put pen to paper and worked out aspects of the design?
Low pressure, 7/8" aluminum body gate valve . . . what else do you need? Seat material, body casting/machining design, stem & seals, actuator?
Not just "skeeming" we have the basic design just need assistance with the final design. We need seat/gasket material and machining design, there is no stem, and is hand actuated via push buttons.
This valve is very light weight and very light duty used for non-corosive fluid transfer.
I can help with that. On here, we're asked not to post our e-mail addresses or phone numbers because the bot programs will pick up on them, so I don't know how to go about getting in touch.
Let's try this: in my member name, take out the "1" and put "_i", then put another underscore after the "n". That will be my address at yahoo.
