Need a stop
Ray2
Military
The easiest way for my application to stop a hydraulic cylinder at the right distance ( in one direction) is to adjust the cylinder so it bottoms out. But something in the back of my mind says I should not do this. Any thoughts on this?
Ray D
It is often done. If the movement is relatively slow you would not need to consider a cylinder with an end cushion. Just move it until it bottoms.
Ted
Thankyou, it does move very slow. Another problem solved
Ray d
You didn't say if it needed to be adjusted in retract or extension. For extension the most common way is to put a sleeve inside the cylinder over the rod. For retraction the sleeve is usually put over the rod on the outside. Ag applications do this quite frequently as a method of depth control, so the stops are available as spling-loaded sections that snap over the rod (though the rods are usually only 1-2" OD.
ISZ
