Need a script changes body size & constraint
AkramAero
Aerospace
Apr 21, 2016
11
Hi every one,
Can anyone help please,
I have a body (3 parts) and I want to write a script
which can change part sizes and constraint (angles between parts).
Thank u
what is the goal? to make changes in hundreds of files? day by day use? for a single part you can do it more quicker without scripting.
Thank you for your replies.
I am not an expert in CATIA scripting. I just wanted to design a C-Wing same as the image, then, via a user interface,
I can handle the whole wing by changing spans, sweeps, aspect ratios, angles..
 http://files.engineering.com/getfile.aspx?folder=2a4048b7-f4b8-4c57-b511-1d82b83f75f7&file=c-wing.jpg
You have to understand when scripting is required and when not. The wing can be simply controlled by parameters.
Thank you JeniaL,
I know it's possible to change the parameters.
But, as I have to conduct tests on many configurations, I think that a macro where
you can change your parameters, will be much better than changing it (parameters) directly .
Ferdo is right. VB/forms is the way to go. Post at least part of a script.
Jenial had a good point and in your case I would go for design table for the following reasons:
That would be easy to setup (much easier than a script)
easy to switch from one config to another
easy to create new config
check online doc about design table
Eric N.
