"Hard enough not to bend". This is going to need clarification. Heat treating this material will not change the modulus of elasticity, so the stiffness will not change. Heat treating it will however increase the yield strength. So if you are expecting the material to deflect less under the same load after heat treatment, you are going to be disappointed.
Maui
