All,
I am evaluating a connection between a steel bracket and an aluminum support structure, fastened by steel blind rivets, and in use for around 30 yrs, on the underside of a railcar. The original design drawings show mica paper called out at the interface, but I can see corrosion at the perimeter of the steel bracket.
Is there a method of non-destructive testing that would help quantify how much of the aluminum is corroded and where, esp. near the rivets, etc.? We are trying to avoid removing the bracket in this evaluation. The goal is to determine if the joint as-is still meets original structural design requirements. Joint is loaded primarily in shear, as a bearing type connection, because the rivets do not provide high clamping.
Any help would be appreciated.
tg
tg
