Hi everyone,
After reading through ASME VIII div 1, some of its code cases, ASME V, and various papers about the subject, I am trying to make up my mind about the most convenient way to inspect the welds connecting set-in nozzles to their duplex vessel.
I would usually stick to the code requirements, however since some welders were just qualified and have little experience in welding duplex, I am nervous about the actual quality of the welds. Some defects also detected by RT in shell butt welds did not help to alleviate my concerns. So I would like to perform some NDE on these nozzle welds, but I could not find any which would be completely satisfactory.
First, the vessel is 8mm thick, in duplex. The nozzle, made either of duplex tube or of duplex rolled sheet, would be roughly 5mm thick. Assembly is as per ASME VIII div 1 Fig UW-16.1 (c) or (d).
According to table UW-12, RT are not applicable. Does it mean it is just not required, or is it also because such type of joint does not permit interpretable radiographs ?
Sometimes, US are considers as a alternative to RT. However I am told that the thicknesses here are too thin, using either phased-array or straight beam (from inside the nozzle).
Does anyone have a suggestion about a test that may give a reliable picture of what the whole weld looks like (i.e. not only dye penetrant)?
Thanks for reading and for your advice.
