NCEES Agricultural PE Exam
wesley_pipes
Agricultural
Anybody here taken the NCEES ag engineering exam? What were your thoughts? What study materials would you recommend?
Ideally, I'd like to get a hold of older NCEES practice exams. I plan to buy the current one on the website.
Yes. I've taken the exam. It was the last paper exam before it went to computer-based. I didn't think it was awful if you have an ag or biosystems engineering degree. Having a good base in stormwater/irrigation/pumps/motors/ basic structural/and being able to do process flows for ventilation will probably be enough. Familiarity with the ASABE/ASAE codes are helpful and ASABE has offered some study material and sessions in the past if you are a member. I did have some older exam practice questions from the ASABE study materials. Between the codes and the exam resource book should have all you need. Good luck!
Thanks for the response. I was beginning to think nobody would respond to this. It is such a niche license.
Any chance you still have the older practice exam questions? I'd like to have at least one additional practice exam besides the current one on the NCEES website. I will also reach out to ASABE on additional study materials.
No problem! For sure, it's a niche license.
I did find a couple exams that I had marked up a little bit and scanned. I couldn't find a virgin copy of those, but I can share with you what I have. Not sure how best to get those to you. I don't see a way to direct message.
Sent you a message!
