NC: Which operation to finish vertical walls and limiting edges?
  • Thread starter Thread starter ArtEng
  • Start date Start date
A
ArtEng
Guest
Hi all, I am trying to machine polypropylene through catia's surface machining environment. When i machine a pocket that has vertical walls, some chip is left behind on the walls and on the limiting edges and it's time consuming to remove them by hand. What do you think would be the best NC operation to finish those features?
