Alistair_Heaton
- Nov 4, 2018
- 9,832
If they are as bad as some of the UK bunkers I don't blame the locals wanting them empty.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
[/highlight]Airforce Mag said:The Army’s Surface Deployment and Distribution Command handles fuel movement by pipeline or rail within the United States and by a variety of means overseas. Because of their locations, most of PACAF’s fuel (and a lot of AFCENT’s) is transported to the host countries under authority of the Navy’s Military Sealift Command. MSC owns three large tanker ships, which can carry 238,400 barrels of fuel each, and charters a shallow draft 36,000-barrel tanker that is used to move fuel intratheater for Japan and South Korea.
All of these ships are crewed by US merchant seamen. MSC also can hire US-flagged vessels to meet the military’s needs.
In PACAF, the fuel goes to 10 major bases in South Korea, Japan, Guam, Wake Island, Hawaii, and Alaska, plus four smaller South Korean facilities and 15 remote Alaskan radar sites. MSgt. Joel Brown, PACAF fuels operations superintendent, said Guam is the command’s largest fuel account, since it is a vital trans-Pacific refueling stop and a heavily used staging base. On average, Andersen AFB, Guam, issues more than 50 million gallons of jet fuel annually, but can store up to 66 million gallons, Brown said.
AFCENT supports 14 bases in eight countries, Murphy said. Those bases include well-equipped facilities in Iraq, Kuwait, and other Persian Gulf countries; large bases at Balad in Iraq and Kandahar and Bagram in Afghanistan; and some small, austere locations throughout that country. The command also supports the US operations at Manas in Kyrgyzstan, a key supply waypoint and air tanker base.
Although the primary fuel used by both commands is JP-8 for fixed wing aircraft and helicopters, they also require [highlight #FCE94F] significant quantities of diesel for ground vehicles and generators, and small amounts of standard automotive motor gasoline (Mogas) for a limited number of vehicles. AFCENT also requires aviation gasoline (Avgas) for some of the smaller remotely piloted aircraft operating in theater. PACAF issues more than 285 million gallons of jet fuel annually, about 40 million gallons of diesel, and about two million gallons of Mogas, Ludwigsen said.
This is from a thesis 20 years ago but I'm fairly certain that the US Navy has adopted JP-5 as a universal fuel.USNPS said:"This research investigates the feasibility, benefits, impacts and costs of replacing F-76 with JP-5 and adopting JP-5 as the single "universal fuel at sea". Joint Publication 4-03, Joint Bulk Petroleum Doctrine states, "Department of Defense components should minimize the number of bulk petroleum products that must be stocked and distributed". DoD currently stores and distributes two fuels, F-76 and JP-5, for shipboard use. As the universal fuel at sea JP-5 would replace F-76. All shipboard systems, including boilers, turbine engines and diesel engines that currently operate with F-76 should operate satisfactorily with JP-5. Adopting JP-5 as the single fuel stocked and distributed for shipboard use would simplify logistics support, maximize flexibility, and enhance the readiness and sustainability of U.S. forces at sea."
It’s because those are standardized assays. The DOH probably doesn’t have a TDH-JP5.TE said:I just find it funny that they use the descriptions diesel like and gasoline like when there really should be no question as to what the fuel is.
A petroleum hydrocarbon mixture may contain several hundreds of individual sub- stances varying according to the original source of oil, distillation fraction, type of emission, and weathering of the mixture in the environment. Therefore, due to the com- plexity of mixtures covered by term "total petroleum hydrocarbons" it is quite understandable that two different methods measuring "oil" will always give different results at least for some samples. However, it is difficult to find other ways to define oil in other ways as by an analytical determination. Rather than having one possibly less robust method covering all possible definitions, a set of methods used alone or in combinations allows determinations related to the relevant environmental standards in each case [43].
Compared to present methods offering a possibility to determine separate hydrocarbon fractions and toxicologically most relevant individual substances, the old infrared spec- trometric method had various restrictions. The general trend is to base the risk assess- ment on determination of various oil fractions and specific contaminants posing hazards (like the BTEXN, PAHs, oxygenated gasoline additives and specified aromatic and ali- phatic fractions) – not on one index not necessarily determining more than one type of substances in the hydrocarbon mixture.
In other words, the extraction rate, detector response, and losses during the determina- tion of individual substances present in total petroleum hydrocarbons may vary method by method, and mixture by mixture. Instead of measuring a general hydrocarbon index by IR or other detection method, present detection equipment allow further analysis of TPH constituents needed to assess the real environmental behaviour and toxicological properties of a TPH contamination.
What Are the Chemicals of Concern?
The Red Hill Facility currently stores and dispenses three types of petroleum fuel - marine diesel for ships and two types of jet fuel, JP-5 and JP-8. Historically the facility also stored Navy Special Fuel Oil, Navy distillate, motor gasoline and aviation gasoline.
Based on the current fuel stored at the facility, the chemicals of most concern are referred to as middle distillates. Middle distillates include total petroleum hydrocarbons (TPH), benzene, toluene, ethylbenzene, xylenes, naphthalene, and methylnaphthalenes. More information can be found in Section 9.3 of the Hawaii Department of Health Hazard Evaluation and Emergency Response Technical Guidance Manual.
Tug said:I'm fairly certain that the US Navy has adopted JP-5 as a universal fuel.
