Alistair_Heaton
- Nov 4, 2018
- 9,832
If they are as bad as some of the UK bunkers I don't blame the locals wanting them empty.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Alistair_Heaton said:The military used to have a thing called crown exemption which was removed about then.
Gasoline has a higher LD50 than ethanol yet we often voluntarily drink the latter.
HONOLULU – Samples collected from the Navy’s Red Hill drinking water shaft on Sunday December 5 tested positive for high levels of gasoline and diesel range hydrocarbons. This is consistent with visual observations and odors detected by Hawaiʻi Department of Health (DOH) staff when the samples were collected.
DOH received the detailed lab reports late last night. The reports were immediately analyzed by DOH staff.
Samples from the Navy’s Red Hill Shaft contained total petroleum hydrocarbons diesel range organics (TPH-d) 350 times the DOH Environmental Action Level (EAL) for drinking water. The Red Hill Shaft samples also tested positive for gasoline range organics more than 66 times the DOH EAL.
The DOH samples were analyzed by Eurofins Laboratory in California. Eurofins found 140,000 parts per billion (ppb) of TPH-d. The DOH EAL for TPH-d is 400 ppb. Eurofins found total petroleum hydrocarbons gasoline range organics (TPH-g) at 20,000 ppb. The EAL for TPH-g is 300 ppb.
