Hi people
I am trying the suggestion of wordpad. Thanks.
I will do the last item on the list , plus two others.
If you start with a wire in free space it will generate
a magnetic field around it. As you get futher away
from the center of the wire the mag field is less,
(the same rules of radio transmittation)
To make a very very long story short, the very
center of the wire (due to the induced mag field)
opposes the flow of current. This makes the center
of the wire not as conductive as the outer edges.
The result of this is most of the current flows on
the outside of the wire (on the "skin"). Sence the
conductivy (call it effective area of wire at the fc) of a given wire,
is dependent on the "active (cross section)" wire. The higher
the frequency, the more loss in the wire, compaired
to its dc conductivity component.
At one time I used a "MS BASIC" program that I
had written to calc skin effect, yes that important.
Form my previous comparesion of 60hz to 400hz transformers
the numbers are for 60hz = .358 inches, and for 400hz
= .1377 inches (this is the number which states the "ratio of loss")
(this is about the 50% loss nunber ? level if I remember).
While this is not much for home use
(most home wire is less than .133in in dia) too small
at 100 amp in out, think of power companies).
Lets see .358/.1377 = (1.599-) call it 1.6 times. This loss ratio is
per inch, or foot, or mile or 1000 miles. If I could reduce my losses
to 1/1.6 = 1/.625 = .375%. I know I would do it without thinking.
Put it another way, if you were designing a power system, ( for a power co.)
and had to put 10K or 100M amps (in a wire) this would be very important in
your transformer design and wiring. That is why power conpanies
try to do the best answer (for them the answer is 60hz).
For them 60hz is the best answer, of the tradeoff of total energy
transfered verses size, fc. etc.
Skin effect is related to fc numbers but it is also by nature
related to current, for losses (I^R) it is a resistance rato at best.
1 amp (losses) are dfferent than 100 amp losses, (the square factor of current).
What is not said, is if you are designing a 60hz or 400hz
transforner, unless you get to the .1inch wire dia do not worry (min effect)
unless you are pushing it to the limit, where 10% is a make or break thing.
How about a new concept (problem) with wires.
If you extend the concept of (skin effect) to related wires in a coil,
you end up with a concept of wires carrying currents next to each other.
Start over except that all of the concepts about skin effect apply.
Proof is, what is the difference in mag flux and its control of resistance
based on the center of a wire (take a number .1(skin )),
verses a wire placement .02inches, removed from the center of the wire.
This is called the proximinity effect. The result is it still pushes the wire
current into a smaller portion of the wire, only now to one side.
The third major effect is due to ac currents generating voltage (and therefore)
current loops within the magnetic material as well as in the wiring.
This is eddie current effects, and can be very lossy.
The result is, if a wire has current
in it, it is subject to many various effects, (these effects can be most dominant).
Just to make sure that you understand the results of the concepts.
A design for a 1000 watt transformer "can have (10watts 100watts 1000watts loss)."
It all depends on the base magnetic losses as well as the, fc, wire size,
nunber of strands, size of strands, and on and on, than you get into the mag material,
where it starts all over again.
Yes I understand , the original question was answered.
Question is did you learn anything, or was it too much and became
just words.
Have expanded it with your approval ?
My concept is to let you be exposed to the problems involved
in a 60hz verses 400 hz transformer, and the base concepts that
drive these designs (which are not throught without an unstandering
of the higher fc components, as well as the low fc components).
Like most things, there is no set answer .
I have had eng tell me that they have had two inch dia
bolts melt due to eddie current losses in large 60 hz units.
I am just trying to expose you to something more than the
"yes, no" answer
Did any of this make sense?.
I think my head hurts, not a normal ake, it just hurts thinking
about all of the concepts explained, and not explained.
One thing to the general public (and you mil people in specific)"I design to the mil specs, but am not in the mil".
"LOOSE LIPS SINK SHIPS".
I have been waiting 50 yrs to be able to put this in contex.
I think this runs over 3 or 4 days, hope it is not too much,
I still do not know how much you want, please let me know.
Oh I almost forgot, more detailes can be found if you do a
specific search for "UNITRODE" added words "SEM",
go directly to the "TI\FOCUSE" website, (HANG ON TO
YOUR MIND), it gets very complex very fast, but many good
things can be understood (pick and chose).
Next or not, what to go to now.
