I'm inclined to believe that, apart from ocean tidal change frequencies imposed by gravitational effects of the moon and sun, the natural frequencies of or water and other liquids are those imposed by the geometry of the confining structure whether open channel (dams, weirs, bays, lakes, etc) or closed channel in pipes and pressure vessels. In closed channels, one finds the infinite variety of so-called flow tones and flow-induced-vibration (FIV) sources that can disable or fail equipment and drive responsible equipment engineers to distraction if not pure insanity. One of the daunting problems of FIV troubleshooting is that the same physical geometry can generate more than one type of flowtone source (eg., Helmholtz resonator and annular channel standing waves), having vastly different frequencies, depending on the range of flow velocities passing the "mouth" of the cavity in the structural wall bounding the fluid flowpath. vanstoja
