When I left Toronto, Ontario had its own Building Code and last I knew the 2006 Ontario Building Code was in effect... best you try to obtain the code in effect. The OBC was a re-write of the preceeding NBCC... and may be the 2005 edition of the NBCC.
They had a separate document. In Manitoba, we reference the NBCC, but with modifications.
About 20 years ago, there was a minor tremor in Toronto... felt like a heavy vehicle passing if you are on the second floor... this was slightly felt on the 8th.
Dik
