Hi all,
I recently build a circuit using Logic Level P-Channel Mostefs to drive a 24V load from a microcontroller 0-5V level.
Gate to microcontroller, Drain to Load and source to 24V.
That dind't work. Works only at 5V. From 5V up the transistor is allways on. I think I need to use some kind of mosfet driver. (I was thinking that using a Logic level transistor was enough). My mistake.
Aparently such a simple circuit is possible using a N-Channel Mosfet. Gate to microcontroller, drain to Load and source to ground. Since we are "giving ground" to the load everthing works.
Can you guys confirm this?. I think I still have a lot to learn concerning circuit design..
I dont want to make more mistakes.
Thanks in advance
M.
Thanks in advance
M.
