My swept blend keeps twisting!! HELP!
  • Thread starter Thread starter saqademus
  • Start date Start date
S
saqademus
Guest
trying to model a fairly simple shape using swept blend, but after I get to the third section, it comes out all twisted???
I've read that I just need to "drag the start point" but i dont know where it is or how to drag it? I've tried click dragging the circular white box but no luck
Help please! Thanks
Check the start point of all the sections.....
to change the start point click the point and right click
on that point you will get the start point option.....
All sections must also have the same number of entities.
try it as a boundary blend and manage the control points.
Help please! Thanks
Edit Definition on the swept blend and enter sketcher again. For each section you'll see a yellow arrow on a vertex. As you right-click and choose "toggle section" whenever you see an arrow that you want to change, select a new vertex, right-click and select Start Point.
Definitely start points. Do you have a picture you can post?
