My Macros stopped working with upgrade 1
boottmills
90
We updated to SW 2007 sp5 over the weekend and none of our macros are working any more. When I go to debug, it yellows out the Sub main () in the first code line. Does anyone have any ideas of what would be causing this or how I could fix it?
Here's the one I tried to run this morning.
Option Explicit
Dim e As Long
Dim w As Long
Dim dxfver As String
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim sPathName As String
Dim s12DXFPathName As String
Dim s14DXFPathName As String
Dim sPDFPathName As String
Dim sCNCPathName As String
Dim swDraw As SldWorks.DrawingDoc
Dim nErrors As Long
Dim nWarnings As Long
Dim nRetval As Long
Dim bRet As Boolean
Dim bRet2 As Boolean
Dim bRet3 As Boolean
Dim Part As Object
Dim SelMgr As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Dim Feature As Object
____________________________________________________________
Sub main()
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swDraw = swApp.ActiveDoc
Set SelMgr = swModel.SelectionManager
' swModel.PrintDirect
' Strip off SolidWorks drawing file extension (.slddrw)
' and add DXF file extension (.dxf)
sPathName = swModel.GetPathName
sPathName = Left(sPathName, Len(sPathName) - 7)
s12DXFPathName = sPathName + ".dxf"
's14DXFPathName = sPathName + "_R14.dxf"
sPDFPathName = sPathName + ".pdf"
'sCNCPathName = sPathName + "_CNC.dxf"
dxfver = swApp.GetUserPreferenceIntegerValue(swDxfVersion)
swApp.SetUserPreferenceIntegerValue swDxfVersion, swDxfFormat_R12
swApp.SetUserPreferenceIntegerValue swDxfOutputNoScale, 1
bRet = swModel.SaveAs4(s12DXFPathName, _
swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, _
nWarnings)
If bRet = False Then
nRetval = swApp.SendMsgToUser2("Problems saving DXF file.", swMbWarning, swMbOk)
End If
bRet2 = swModel.SaveAs4(sPDFPathName, swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, _
nWarnings)
If bRet2 = False Then
nRetval = swApp.SendMsgToUser2("Problems saving PDF file.", swMbWarning, swMbOk)
End If
'swApp.SetUserPreferenceIntegerValue swDxfVersion, swDxfFormat_R14
'bRet3 = swModel.SaveAs4(s14DXFPathName, _
'swSaveAsCurrentVersion, swSaveAsOptions_Silent, nErrors, _
'nWarnings)
'If bRet3 = False Then
'nRetval = swApp.SendMsgToUser2("Problems saving DXF file.", swMbWarning, swMbOk)
'End If
'swDraw.ActivateSheet ("program")
'bRet3 = swModel.SaveAs4(sCNCPathName, _
nWarnings)
' nRetval = swApp.SendMsgToUser2("Problems saving DXF file for programming.", swMbWarning, swMbOk)
'End If
' Restore old setting
swApp.SetUserPreferenceIntegerValue swDxfVersion, dxfver
Set Part = swApp.ActiveDoc
Set SelMgr = Part.SelectionManager
Part.ViewZoomtofit2
Part.Save2 False
Set Part = Nothing
swApp.CloseDoc (sPathName)
Boottmills
What version did you upgrade from?
Try going to tools->References. Check to see if any are missing, and re-order them a bit. Sometimes you just have to force it to look for them again.
-handleman, CSWP (The new, easy test)
I upgraded from SP2 to SP5. I'm going to check the references and see what happens..I'll let y'all know!
Boottmills
YOU DA (HANDLE)MAN!
It did the trick! Thanks!
Boottmills
