powersoff
- Jan 16, 2008
- 80
I had (13) 20hp,480volt 3phase motors running at the same time . The 480volt feed terminates at a tap block which then feeds fuses for each motor, contactor and ol's.
15 fuses feeding 5 motors blew.
That left me with 8 motors running.
Only 1 of the 5 motors was identified with a problem no continuity phase to phase.
The other 4 motors fuses were replaced and have been running ok.
The fuses that blew were mounted adjacent to each other on a din rail.
If 1 motor has a open winding could this have caused all 15 fuses to open?
The fuses are 45amp LPJ.
