multiple lines in the custom properties?
DanielRo
Nuclear
Feb 22, 2008
32
In my custom properties there is a Designer field. Sometimes one designer is required to be entered below another. What is the symbol to use to add an extra line below? I thought it was the carriage return symbol between names but I can't seem to make that work.
Thanks in advance.
Oddball workaround:
Type your text including line breaks into Notepad. Copy and paste text into your custom property.
Gaah! How could I forget. You may have learned that from me.
thread559-186684
I use alt+0010. How do you enter this??
I can't get the second method to work
You need to type the numbers on the number pad of your keyboard while holding <alt> down.
