I have a 3/8" diameter rod that will occur many times in an assembly but each time the length is different. Is there a way to draw it once and control a variable to vary the lengths for each one or do I have to develop each part file one at a time?
I thought I might be able to make an assembly pattern, drop the pattern, break the links and then change the lengths but it maintains a link somehow.
The assembly is a rolled square tube 40" diameter with the rods placed parallel to each other spaced 1-1/2" apart setting on the face of the tubing. The rods ends are cut so they do not extend beyond the diameter of the tubing.
Jef
Jef
