I have assemblies that i download from suppliers, liek skf bearings. They are great and very detailed. The problem is sometimes they are too detailed. A large bearing may be an assembly of 100 parts. Add a few bearings and my assembly goes from 20 parts to 420 parts.
I want to change the bearing assembly to 3 parts instead of 100. The housing, the seal, and the roller/sleeve part. The roller/sleeve part is the one that has 50-100 parts as it has each roller modeled.
If I select all 50 inside parts, and "SAVE AS" and select part instead of assembly, it converts everything to surfaces instead of solid bodies. Mass properties continue to work, but section views do not, which unfortunatly I need.
Does anyone know a better way to combine an assembly into a single part?
Randy
Randy
