gagne73
- Jun 8, 2011
- 22
I have a underground parkade to design, with 2 storeys below grade. At this point I am getting a headache trying to determine my clear cover for all reinforcing within the structural slab.
It appears that according to Table 17 (CSA A23.3#-14) tells me I MUST have minimum 60mm concrete cover for all beams/slabs/columns, solely based on the type of exposure that I have. This, conveniently also satisfies requirements I have for 4hr ratings as well. For the beams, does this mean cover to the stirrups, or to the primary beams?
big question I have with that, is would you follow these covers for the upper structural slab as well? THe structural slab has parking BELOW it, but is commercial space directly on top. I am undecided of my exposure for that slab, as it doesn't have direct exposure to chlorides, but it will be humid from time to time, with more corrosive air.
Another issue, is that having 60mm of cover makes me a little bit concerned about cracking, is this legit?
I would really appreciate a bit of a response from somone with more parkade design experience. I havent really been able to find quite what im looking for on here, although there are similar posts. Its pretty important, as having 60mm cover on both top and bottom of slab makes for a thicker slab/beam for sure.
