Multi-Stage Single-Outlet fire Pump 1
Alireza01
IR
Is it permissible to have a Multi-Stage Single-Outlet fire Pump according to NFPA 20?
From the AC Centrifugal Split Case Fire Pumps O&M
Picture is a cross section of a two stage split case fire pump.
Pick type listed fire pumps using the pump's curves. As long as the pump is UL listed as a fire pump, it can be used in a NFPA 20 application.
