RichLeimbach
I am currently using a brush-type DC motor to drive a relatively high inertia flywheel from 0 to 15K RPM in approx. .5 sec with a DC source (battery).
The problem I am running into is that with a single, always-on gear ratio, we spend too much time in the high current, low speed, low efficiency range (< 1/2 the max motor speed) and I'm having durability and heat related problems with the current motor. Electrically modulating the applied voltage does not help, as it just increases the time the motor spends in this inefficient range.
Besides finding a way to mechanically shift gear ratios, is there any way to increase the low-end efficiency of a DC motor? I am thinking of something along the lines of 2 speed AC induction motors, but in DC form. Any ideas?
