M
maurya
Guest
When we are working with MULTI SHEET drawings,to go to another sheet;what we do generally is to choose Format --> Sheets --> Next/Previous.Use this to make this task simple.
Note: This workaround holds good for scroll(wheel) mouse,perhaps it may work for button mouse also,but I haven't tried.
1.Make the model tree active.
2.Place the cursor anywhere in your model window.
3.Now simply move the wheel of your mouse up to
simulate the action of Sheets --> Next;and down to
get Sheets --> Previous happen for you.
Pl.note that some times you may not get the desired
result,if that is the case simply move the cursor
again,and move the wheel.
DN Reddy,Manchuri.
Edited by: maurya
DN Reddy,Manchuri.
Edited by: maurya
