Multi Hole Orifice Pressure Drop 1
herman74
Chemical
Dec 15, 2007
6
Hi
I have an orifice on a sea water discharge line in order to reduce the pressure to the one present in a downstream common discharge.
Since the pressure drop and the flow rate are quite high (3 bar; 12500 m3/h), our supplier have provided us a DN 1400 orifice, 40 mm thickness, with 253 holes with diameter of 20 mm.
I want to verify this choice (also for personal culture), so I searched our library and goggled the net but I was not able to find a formula that could permit to find the pressure drop of a multi hole orifice as a function of:
-) diameter of the single hole
-) number of the holes
-) thickness of the orifice (length of the hole)
Can anyone help me on this topic.
Thanks in advance
Ermanno
Many thanks casflo for your answer! are you still studing orifices plates? have you other references on this topic, please?
unfortunately I have not many references:
Ball J.W. (1973), Tullis J.P. (1975)
Fratino U. (1999, 2000)
simo 78, try in and look for the paper ESDU 81039 titled "Flow of liquids. Pressure losses across orifice plates, perforated plates and thick orifice plates in ducts".
Regards.
