I am currently designing an instrument air distribution pipeline (for actuators, control valves etc). Working to a specification, it states "Piping from the isolation valves on the main instrument air supply header to individual consumer shall be of galvanized carbon steel pipe and NPT threaded fittings". The corresponding carbon steel piping specification only mentions a standard "MSS SP-95" AND all valves are to be ASME flanged, not threaded at all. I have never worked with NPT threaded pipe before (only tube compression fittings) and the concept of threaded galvanised *piping* is foreign to me. Could someone explain (a) whether MSS SP-95 and NPT standards are interchangeable; and (b) why would galvanised piping be used?
Thanks in advance, SF.
