I have seen previous posts about MSE walls with barriers, but I still need clarification.
Currently, Caltrans requires the use of BDS LFD for MSE wall design in lieu of AASHTO LRFD. Caltrans requires designing the moment slab and top row of MSE reinforcement for traffic impact. However, it is unclear what this impact force should be. The 54 kip load seems way too high, but I can't find anything about the 10 kip load from AASHTO in Caltrans BDS. All I can find is the 1.9 k/ft load for the top reinforcement (BDS 5.9.3.8.2), which still seems too high. I checked the standard XS sheet barrier slab overturning with the 1.9 k/ft load, and it doesn't work.
If anyone has an idea about what loads to use for 1) the moment slab, 2) pull-out, or 3) reinforcement tension, and where these are specified, I would appreciate it.
Thanks!
Thanks!
