Here's a really strange one.
I was reviewing a MSE design the other day, and the (well known and very well respected) supplier assumes ZERO corrosion at the connection between the tie strip and the reinforcing strip. After some inquiry, I learned that the theory is that the tie strip acts as a gasket for the reinforcing strip, so no corrosion occurs on the reinforcing strip at the bolt hole. Also, only the exposed face of the tie strip suffers corrosion.
Well, I've been on sites and seen these things cast in strange angles and bent all sorts of ways so I just can't buy that no water gets in there, but they say all State DOT's accept it. By my numbers the design life is half of what it should be.
AASHTO says all connection elements need to have corrosion allowances, and to my thinking a hole in a strip is a critical part of the connection. I'm thinking that too many DOT's may let geotechs run with approving the design without getting structural involved. Who knows what the panel design would throw up?
Any thoughts?
Any thoughts?
