Hope this makes sense...
Hmmmmm... the OP... Miguel D... appears to have stepped away from this thread...
KWK, all... in my experience...
Prototype/pre-production assemblies... should give fairly accurate 'sniff-check' for making last-minute adjustments to drawing sheets and PLs for 'grip-length'. AFTER That... Production should make for fairly stable 'stack-ups' and grip length should be monotonously stable.... and procurement can get the 'exact right parts' to the shop floor
'Hard fasteners'... Bolts, Lock-Bolts, Blind-Bolts, Blind-Rivets, 'specialty pins', bushes/spacers, etc... MUST have all fastener elements perfectly described/specified... long-lead times and Big-Buck$... demand it.
I expect that experienced mechanics could select their own/team's solid/driven rivets from 'shop-floor-bins' for small repairs and modifications fairly reliably.
I have noted that in shops where the assembly mechanics are 'in-charge of selecting the right GL rivets for every riveting task' for bigger jobs... after they get into the 'rhythm and swing of things'... THEY, with the help/blessing of their immediate leads/supervisors... will set-up an informal-but-organized 'system of rivet bins for every job/Assy to speed-up their work'. YEP, NOT STUPID.
BUT-BUT-BUT... trust, BUT verify!
Here is [just-one-of-several] PRECAUTIONARY 'noshit' experience that I had [+28-years ago]. In one USAF sheet metal shop... filled with young mechanics... I was asked by one mechanic "why some rivets are 'easier-to-shoot' than others??". THAT was an ODDLY disturbing question!! Soooo I went poking-around in the shop rivet bins... and found identical size/color aluminum rivets... EXCEPT: (a) most had a 'Raised Teat' head-code marking = 2017 'D' rivets... OK, the correct rivet for their job. HOWEVER, I ALSO found... mixed-into the same bin-trays... a lesser percentage of rivets that had indented 'Dimple' head-code markings = 2117 'AD' rivets... which are significantly lower strength that the 'harder/stronger' 'D'-rivets. Collectively, we discovered other bin-trays [different diameters and GLs] with this SAME mix-up-of rivet types.
OMG... NCOs and I inspected several aircraft in-work... where work was on-going replacing solid rivets in a flight-critical splice-joint. We found randomly mixed/installed 'D' and 'AD' alloy rivets the full lengths of every joint. The junior NCO/officer shop supervisors were in disbelief... and the shithitthefan. Several Jets in-work and few flying jets were affected. What a hot mess: Someone had dutifully stocked the same bins with [2] very different alloy rivets. This is just one of MY many-similar experiences.
Thanks to one young airman asking me a simple and puzzling question that was bugging him... we identified a serious issue and were able to take 'swift/painful' corrective actions.
My conclusion: well-meaning mechanics often aren't experienced-enough to notice fine details and spot when 'something isn't kosher'... and speak up.
Are You using the NAS523 FASTENER CODE, or corporate equivalent? IF SO, then You are committed to the NAS523 'system' which clearly include GL in the code.
Regards, Wil Taylor
o Trust - But Verify!
o For those who believe, no proof is required; for those who cannot believe, no proof is possible. [variation, Stuart Chase]
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion", HBA forum]
o Only fools and charlatans know everything and understand everything." -Anton Chekhov
