MS/NAS Gurus please come hither. 1
uGlay
Greetings fellow Eng-Tippers. Today I bring a query that regards hardware substitution in an aircraft manufactured by McDonnell-Douglas. (DC-9-50)
I need to find a bolt similar to HL11VAZ-6 but WITHOUT flush head and WITH either a hex or phillips slot. I know it's a long shot but maybe one of you has used something like this recently.
Background: We are installing antenna structure that utilizes 0.071" thick doubler on belly section of fuselage, around STA1050. Problem is that the Hi-Lok's collar is falling under the Longeron flanges and as a result we cannot tighten collars properly. We can fit a wrench alright, but it would be to install a simple nut such as MS21043 not a double-height HL collar.
Any help is greatly appreciated. I am also looking through SRM's substitutions section in hopes of finding something compatible. I attached a quick sketch of the section in order to give you guys a better visual of my problem.
Cheers,
uGLay.
SW2009 Office Pro SP2.1
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
KirbyWan;
Do download the paper I attached in a previous post. The PIC bolts are real handy sometimes. They are production parts on the MD-80 if my memory is right.
Dan,
I looked at it. I'm going to keep it in mind the next time I run into that problem. This is a better solution then drilling a hole if you can get the fasteners in a reasonable amount of time. Thanks for the info.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
uGlay...
You need a protruding or flush head screw?? You confused me right off the bat
There are plenty of flush-shear head, flush tension head and PH bolts with various recess designs!!!!
Any space to install nutplates or gang-channel NPs???
Regards, Wil Taylor
