ZI did not mean to sound flippant, but have you examined the juncture of the head & shank of your "replacement" bolts? The MS20074 tension bolt has a very important radius designed into this juncture. There is a special chamfered washer, that in tension applications must be used with this bolt. I have seen many bolts in the field ( same spec, different d. ) with the heads popped off, due to someone installing the washer 180 out, & torquing to spec. Call any wheel shop, I bet their NDT guys can enlighten you.A hardware store bolt grade "whatever" has no inspection system in place, is not approved for aircraft use, even in the experimental catagory. Ask your DAR inspector about it. As for "supertanium", can you define what standards "supertanium" is inspected to?
