merlin1012
- Jun 5, 2025
- 4
Hello all,
Currently using Creo 11 (recent update to).
Tried moving radial (& diameter) dimension by just grabbing the text but it only changed the length of the leader. When I grab the leader it "rotates" along the arc.
I use to be able to grab the text & do both.
Is there some setting for Drawing or Config.Pro that needs to change so I can just grab the text & relocate the text where I want rather than the two-step process of change angle of leader then change leader length?
Thanks,
Merl
Thanks,
Merl
