moving object in a circular path
haque11
Hi to everyone in this blog.I have been trying for a month for making simulation of incremental forming process. I need to move the ball shaped die in a circular trajectory and continuously reduce the diameter of circle with the dept. But the die only can rotate with reference point. I tried to make circular trajectory by placing the ref point away from the die. But it make the work complicated when I need to reduce the diameter of circle with dept. Can anybody give me a solution plz..
tnx Rob. I got an alternative using Amplitude. But it does not work that accurately. I tried on your option.But I am still new abaqus user. I cannot configure cylindrical coordinate.Can you give me a hints on it, so that i can try ..
download.aspx
Rob Stupplebeen
