jfgaltenco
Petroleum
HI there,
This is my first post here but I have not found anything relevant to my problem.
I have to work on modernizing a process that involve moving potentially explosive gas.
My real life experience with compressor as of today is ZERO, so please bear with me. I know I have a lot to learn here.
I have 2 pressurized tanks same volume [1m3 each] separated by ~10000' [ not my choice this is a given I have no control on it].
Initially one tank is at 4000psi absolute the other at ~28 psi absolute. temperature is ambiant
The process I am working on requires the gas to be transferred back and forth continuously between the 2 tanks.
each transfer must be completed in ~2hour 2h30 max [ there is cost tradeoff involved in selecting exact duration of this transfer] [ so average volumetric flow rate is relatively low]
Constraints are
because of safety issues, suction pressure can NEVER fall below atmospheric.
because of the length and size [3/4"] of the line between the tanks, a relatively important friction induced pressure losses toward the end of each cycle exists.
I need an energy efficient compressor package that will perform this function [24/7 continuous operation]. it is not difficult to figure out how to do it in principle.
what I THINK I need is a package :
multi stage compressors 4 or 5 stages with interstage cooling, not sure at this point, each stage is individually short circuited by a check valve so that when inlet pressure exceed outlet's foreach individual stage, one does not compress gas that dont need to be compressed. [ energy efficiency is important here].
to be clear initially the gas flow naturally between the tanks until the 2 tanks are at the same pressure then one check valve close and only one stage is used.. when single stage capacity is not enough because of the decrease in the evacuated tank pressure.. second stage come online through the closing of the second check valve.. and so forth]
and then Variable capacity control is required to LOWER the inlet capacity toward the end of a transfer cycle to decrease pressure losses in the gas line between the evacuated tank and the compressor in order to achieve required evacuation while suction pressure remains above 1atm absolute. the decrease in capacity.
well I am pretty sure this problem must have been already adressed in this form or something close to it many time before me, but I am not able to find a vendor that has already done some packaging to adress this kind of problem or even a reference or a publication..
SO if somebody here could point me in the right direction this will be very much appreciated.
Thanks a lot in advance...
JF
Constraints are
JF
