Mouse wheel zooming
  • Thread starter Thread starter Brian Stirling
  • Start date Start date
B
Brian Stirling
Guest
Is there a way in the newest versiosn of AutoCAD LT to configure the mouse wheel to zoom into the point where the cursor is? That is, by default when you use the mouse wheel you zoom in or out from the center, but I have seen in some of the tutorials that you can zoom in to the point where the cursor is and not the center.
Brian
mouse zoom
Depending on how you have your mouse configured try pressing the roller wheel it should turn to a pan icon on the screen. hold and move cursur to the center of the screen. Then roll the wheel for zoom.
Considering you said you are using AutoCAD LT you will not have much control on how you can custmize. LT is a stripped down version of AutCAD. Thats why it was much cheaper than the full version. Hope this helps.
Ozzy
