mouse clic cause the computer to freeze 1
iders
Automotive
CA
When I clic on the center mouse button, the computer freeze sometimes. I use Catia V5 R13 SP3 on IBM station P4 3.08 Mghz Zeon. The machine is new and I didn't haved this problem before with the other IBM zeon computer. (P4 200Mghz). Do somebody know how to resolve this problem?
Have you tried resetting your catsettings? Delete the existing ones and start over and see if that helps. Could be a corrupted catsetting, but couldn't tell you which one.
Good Luck.
Thank you for your answer but I fond what cause the problem, it was the mouse USB peripheral. I switch the mouse to the DIN peripheral and the problem has been resolve.
In that case, you will want to update your motherboards BIOS.
