Having a cast Aluminium enclosure with the 3mm wall thickness. now I need to mount this to a mounting plate which fixed in vertical walls. can I have some idea on how should I choose the appropriate fastener?
1. Cast Aluminium enclosure
2. mounting plate, for now, I have placed a 5M countersink bolt
Enclosure can't be changed. this mainly mounts on the railroads it should withstand 20g RMS shock. this is the only way I found to mount the enclosure to the plate since I have to maintain the water-resistance. and have to mount vertically.
Total enclosure weight around 800g
my worry is thread engagement and how can select the way to mount.
Thanks in advance.
Thanks in advance.
