RRaghunath
330kW Motors rated at 6.6kV or 3.3kV probably cheaper than those rated 11kV. But in many cases clients may have only 11kV as next higher voltage rating after 415V in the plant and for obvious reasons would prefer to go for 11kV rated motor though the kW rating is low.
In case the switchgear is vacuum type, I think one of the problems could be the switching surges and probable motor failures caused by that.
Any experiences!
Any experiences!
