Thanks for the input.
Yes, I am trying to calculate the max. inertia that the motor can turn. I have some GE 15 Hp motor data sheets which gives you all the information you need, such as max. inertia, acceleration time w/ max inertia, cold and hot stall times, and full speed/torque curves, etc.
From Rich Leimbach's equation, I calculated ~0.6 lb-ft2 (using the density of Iron for rotor material). The GE motor data sheets that I have state 2.0 and 2.17 lb-ft2 each(for a reference). I suspect that my motor is in the ball park of these two machines.
Electricpete, the max. inertia that a 15 Hp motor can safely accelerate is 75 lb-ft2 (from NEMA, MG-1). Unfortunately, the motor in my application is starting a much larger load. I have almost no motor data other than nameplate.
From your formula, "J1 = J2*(N2/N1)^2", how would the load speed be different than the motor speed? Some kind of coupling?
Thanks.
