I'm working on getting either better pictures or the item itself. A correction on the first post - this was not an OEM part. The OEM part has 15 teeth, this one has 14. A point was raised elsewhere that "less teeth works the chain/sprockets harder". I can find no objective, professional data reference this hypothesis. Anecdotally, many, many owners of this motorcycle operate it with a 14 tooth option as the stock gearing is rather high for most non-Autobahn, non-competition purposes. I can find no similar issues or even increased failures of any sort related to the 14 tooth option. It would seem to me that since the torque multiplication is numerically higher for the smaller sprocket that the countershaft sprocket would actually be transmitting lower torque at a higher RPM in order to generate the same rear wheel speed/torque for a given operating condition. Also, when I obtain the part or better pictures, might this topic be more suited for the Gear & Pulley and this thread red-flagged?
